Hello All,
Could any one give me easy code for importing from excel? I dont want to use dataport
Hello All,
Hey Imran,
You could check the standard code used in NAV in example G/L Budget Imports (and Exports).
I have seen that, but i want easier one, just pls give me small example of the import.
Excel is a rather complex format (even the new XML based format of Excel 2007) and I can’t really recommend you any other easier way.
Unless you of cause do what most users do when they have an Excel file they just want to import a few times.They simply save the file in CSV (comma delimited format) and import the file using Dynamics NAV’s dataport. THAT’S EASY! [:P]
Also using the word “easier” might not be the best way to put it across.It makes you look like you want a quick fix.One way to become an expert is to try and crack the how to yourself…[:)]
Hey Imran,
Using the Excel buffer is actually very very easy.
At its most basic each record your place in the table is a cell in Excel with a row and column Id, plus the text that you want outputted.
So to use it all you need to do is repeat through a record set, For each new record you increase the RowID and reset the ColumnID.
For each field you want to export send out the RowID and ColumnID and that should be it.
You can create a Global of the Excel Buffer and make it temporary.
Once the XLBuffer table is populated you can use its inbuilt functions to create the Excel Book.
Don’t be afraid and give it a try, any problems let us know
/TH
Doh, just realised you said import! LOL.
Its just as easy. Use the Function in Excel Buffer Table to import the data in from the excel book.
XLBuffer.OpenBook(Filename,XLBuffer.SelectSheetsName(FileName));
XLBuffer.ReadSheet;
Then I tend to use a report based on Integer.
OnPreReport
Setrange(number,1,TempExcelBuffer,Count);
OnAftergetRecord
If number = 1 then
XLBuffer.Find(’-’)
else
XLBuffer.Next;
// 2 Ways to recognise new Row. Keep Track of Row No. here or use the fact that the record if back to the first Column
If OldRowNo <> XLBuffer.“Row No.” then begin
NewRow;
OldRowNo := XLBuffer.“Row No.”;
End;
Case XLBuffer.“Column No.” Of
1 : //Column A
2 : //Column B
3: //Column C
End;
Hope that makes sense let me know if not
/TH
Thank you so much for the help. Your code helped me alot and understand.
can you give me sample…
like how to import customer from excel
thanks
you want to import from excel? or import to excel?
import from excel
let say… to customer table
Hi Stan,
Why not use (or look at the code) in the data migration form.
Hi Dave,
i thought in CU Migration management using xml
ImportFromExcel(XLSDataFile : Text[1024])
IF ISCLEAR(XlApp) THEN
IF NOT CREATE(XlApp,TRUE,TRUE) THEN
ERROR(Text019);
XlApp.Workbooks._Open(XLSDataFile);
XlBook := XlApp.ActiveWorkbook;
TmpXmlFile.CREATETEMPFILE;
XMLDataFile := TmpXmlFile.NAME + ‘.xml’;
TmpXmlFile.CLOSE;
TmpXmlFile.CREATE(XMLDataFile);
TmpXmlFile.CLOSE;
XMLDataFileClient := “3TierMngt”.DownloadTempFile(XMLDataFile);
ERASE(XMLDataFile);
XmlMaps := XlBook.XmlMaps;
IF XmlMaps.Count <> 0 THEN BEGIN
XmlMap := XmlMaps.Item(1);
XmlMap.Export(XMLDataFileClient,TRUE);
IF ImportSetupDataXML(XMLDataFileClient,FALSE,’’) THEN
IF SuppressMessage <> TRUE THEN
MESSAGE(Text021);
END ELSE
ERROR(Text020);
XlBook.Close(FALSE);
CLEAR(XlBook);
XlApp.Quit();
CLEAR(XlApp);
i want to import to table 246 (Requisition Line)
i have 4 fields in excel,which are column A,column B,column C,column D
Worksheet Template Name → Constant
Journal Batch Name → Constant
Line No. → Running no (+10000)
Type → Constant (2 for Item)
No. → Column A
Shortcut Dimension 1 Code → Column B
Shortcut Dimension 2 Code → Column C
Quantity → Column D
what i’m confused is how to know column A,B,C,D should go to what fields in NAV
my Code
AnalyzeData()
IF ExcelBuf.FIND(’-’) THEN BEGIN
REPEAT
RecNo := RecNo + 1;
ExcelBuf.“Column No.”:=1;
ExcelBuf.“Row No.”:=RecNo;
ExcelBuf.“Cell Value as Text” := ‘TEST’;//DELCHR(FORMAT(ExcelBuf.xlColID + ExcelBuf.xlRowID)),’<’,’ ');
IF ExcelBuf.“Cell Value as Text” <> ‘’ THEN BEGIN
ExcelBuf.INSERT;
END;
UNTIL ExcelBuf.NEXT =0;
Window.CLOSE;
ExcelBuf.RESET;
END;
Hi Stan,
The columns A,B,C… are mapped to the corresponding number
A = 1, B = 2 …
So
ExcelBuf.“Column No.”:=2; is column B
can we import from line 2?
because line 1 from my excel is the header only
data starts from line 2
does any body have a help file or step by step to import from excel?
i’m using excel buffer
is excel file → '-04.00
but why in excel buffer become -4
how to make it → '-04.00
because it is a text , not number
