Hi expert,
how to import data from my local drive using import excel function in a remote environment? i tried to but error says “could not create excel instance”.
Hi expert,
Is excel is installed on server /remote machine ??
Hi ,
no, excel is install on the local
Then you might need to install Excel on Server machine for creation of instance of excel
Or else you need to upload data via dataport using text file.
Before my local pc was connected on Terminal Server 2003
Terminal Server or Server has no excel installed
But the TS was down and we buy a new TS 2008 then connect my pc
Why i need to install excel in TS now?
You need to install excel in TS as during creation of excel instance it will look for the application on TS.
Hi Amol,
Thanks a lot…
Welcome
