Import data
Hi everyone,
Can anyone tell me how to import base data in ax2012…
with regards,
harivalla
I think Microsoft is sending out some information in December regarding the import of master data.
There are many threads discussing this in many areas, here are two relating to the item:
http://dynamics-ax.blogspot.com/2011/10/ax-2012-excel-add-in-revisited.html
blogs.msdn.com/…/product-item-data-management-services.aspx
If you are a partner, speak to your local contact in MS.
They should be able to provide you a pre-Alpha tool for importing master and reference data. This tool uses the standard Excel add-in.
