Hello !! When I use the standard import from Adminstration, I get a error !!! DictTable (object), metode fieldName2Id called with at wrong parameter… Are there anybody who know this error, and how it can be solved ?? It’s only sometimes the error happend… Thank !! Paw
Hi Paw. If your setup permits it, try and do a full synchronise of the database, and do a compilation of the entire AOT. Regards, Søren
Kopi af meddelelsen:
Oprindelig lagt ind af s.h.a - 2005 Feb 04 : 09:22:52
