Import Data in Navision 2013 R2
Hi
We need to import MS word table data in Navision 2013 R2 . Is there any way to Import MS Word data in Navision 2013 r2 ?
Is it a one-off or periodic import?
In case you can consider to rename the file changin the extension from *.docx to *.zip, open it and import the xml file you’ll find in the archive, which will contain the data you need to load.
Otherwise using a tool like http://www.codeproject.com/Articles/20529/Using-DocxToText-to-Extract-Text-from-DOCX-Files and create a custom dll to run it from NAV.
