I need an idea from you, in General ledger there is a job to import exchange rates from a provider.
Ax is receiving an xml and parses it and updates the currencies.
In test environment it works in production it doesn’t work. It is the same code, same configuration.
I have tried to do the call from a test application in visual studio on the production environment and it works there. Also I am able to open the xml from internet explorer, meaning it is not a firewall issue.
My guess is something with the encoding, but I am not sure, since nothing is changed and it works on the test environment.
Any idea why it might not work?
