Import Criteria tab not visible in Table Setup form
Hi all!
I’m using AX 2009 SP1 with RU7.
When opening Administration->Data export/import->Definiton groups and selecting a group, pressing Table Setup button, I cannon see Import Criteria tab :frowning:
How can it be?
Import criteria and Conversion tabs allows you to write code to perform the actions, therefore you are required to have permissions for development (SysDevelopment security key). That’s likely the problem.
Thank you!
