Import an XML file from web site to a table
[:D] Hello I’m new, and i’m sorry for my poor english but i have a big problem… I want to import an XML file from a web site in to a table of navision 3.60. Can some one help me? Best regards for all
If you’re having the format on the xml file you can always create a dataport that parses that format. If you’re going to create the xml file based on Navision’s requirements, you can use a dataport for exporting in xml a couple records as sample of the format you can use for importing straight from the xml file to navision (use the xml functionality on dataports navision is having). Regards,
HI take a look on this thread http://www.navision.net/forum/topic.asp?TOPIC_ID=976&SearchTerms=XML and also do a find on Navision Codeunit object with keyword ‘XML’. Hope this will help you
