Hi all
I have a product form where list of products is saved and i need to create a button calles Images . wen that button is clicked that particular Image of the product has to be displayed
Thanks & Regards
Manjusha.D
Hi all
Thanks & Regards
Manjusha.D
FilenameFilter filter = [‘Image Files’,’.bmp;.jpg;.gif;.jpeg’];
BinData binData = new BinData();
str extention, path, nameOfFile;
Container ImageContainer;
super();
imageFilePathName = WinAPI::getOpenFileName(element.hWnd(),filter,’’, “anytext”, ‘’,’’);
if (imageFilePathname && WinAPI::fileExists(imageFilePathName))
[path, nameOfFile, extention] = fileNameSplit(imageFilePathName);
if (extention == ‘.bmp’ ||
extention == ‘.jpg’ ||
extention == ‘.gif’ ||
extention == ‘.jpeg’)
binData.loadFile(imageFilePathName);
imageContainer = binData.getData();
element.showLogo();
element.insert();
set the table column datatype as Bitmap
insert the data (this codin imageContainer )
““wen that button is clicked that particular Image of the product has to be displayed””
display the image:
if (ImageContainer)
logoImage = new Image();
logoImage.setData(ImageContainer);
FrnImage.image(logoImage);
element.resetSize();
FrnImage - ImageField.
ImageContainer - value from table.
Hi Manjusha,
You need to follow 4 simple steps to achieve this task .Go through the steps
Step1: Give Menuitem of CompanyImage in your Product Form.
**Step2:**Add Bitmap Window Ctrl in to ur Form
**Step3:**Write a Image method in Form Level as Follows;
void image()
Image img;
CompanyImage ci;
ci = CompanyImage::find(.dataAreaId, .TableId, .RecId);
if(ci.Image)
img = new Image();
img.setData(ci.Image);
.image(img);
.heightValue(150);
.widthValue(150);
else
.image(null);
Step4:Call this Image method in Form Level Activate method after Super as Follows
element.Image();
By doing this u can get the Image for Particular Product
Have you tried with the Document Handling Functionality???
