Problem is happening is that whenever print the report with filtered record then it display image properly for that record but when print without filter then it print the same image for every records displayed. Image is printing on Page Header.
This is document report printing based on line items entered in sales order.
Does anybody have encountered such problem or any suggestions how we can show image based on record ?
It shouldn’t be impossible. Are you using the same method as on invoice/credtmemo document reports? Transferring the image to the header from the body using code?
in standard reports the images are loaded in trigger oninitreport (calcfields). in your case you need to load them for each record, so in trigger sales line onaftergetrecord (or maybe onpredataitem).
