since now i used to make reports in navision financials 2.6, now i just began to make a report in attain 3.01, i’ve copied report 204 and modified it. the first label i created has the id number 1105000000. is this ok or is something wrong with my license,…
This is perfectly okay. The IDs are issued based on your license - more specificly on the country code and your license type. The IDs are actually only relevant if you are developing multilanguage enabled customizations. Lars Strøm Valsted ------------------------- Software development today is a race between the programmers trying to make better and more foolproof programs, and the universe trying to make bigger idiots. So far the universe is winning.
Hi mlml772 that numbering is ok with the controls, but if you are declaring any functions in 3.01 in the objects created using your license and if even then the user id of the functions is generated in that range then you have to change the id of the functions to a less than 6 digit number. bcoz i had similar problem and you can check the query ‘functions not visible on C/AL symbol menu’ in the forum. and when this was reported to the Denmark i was given that solution, and the bug would be rectified in the upcoming versions… thanx Kumar
Kumar is right. But, happily, it’s one of the fixes in Attain 3.01B. John
