idle navision clients lost connection...
Hi all, I need your experience. We changed our navision server (machine hp proliant with 2000 server) last week, the process was successfully and all clients can use the database, all ok, well… But now, when the clients are idle approximately 1 1/2 hours the navision clients losts the connection and them need to close the navision client and open again. Before server change this issue wasn’t happened. And I think than the configuration of server are the same. ¿Any ideas to resolv this issue?, The users are a little annoyed. Thanks in advance…
Hi, this should be due to the tcp session timeout on the server, or even more precise with the “KeepAliveTime” Parameter, have a look at the following topic: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=4246 Saludos Nils
Ok Thanks… I will see this article later. Muchas Gracias…
