Identifying high risk areas when setting up Change log
How can one best identify the high risk areas so as to setup an effective change log. Do we have some kind of criteria or best practise that one can follow?
For Setting change log
You need to setup change log specially for Master and setup tables
But while setting up for transactional tables you need to take decision which fields you need to setup logs as this will increase the data result in increase in database size.
Thank you very much Amol.
