I have a manufacturing customer who needs to be able to print a label for their shop floor. They need to print the label from a production order but print the Sales Order Number on the label as they run a “make-to-order” production setup. The challenge is that they have a multilevel production order setup. For example, via MRP, a Sales Order for a table has created a production order for a table, which has created a production order for a table-leg, which again has created a production order for a leg-foot.
The challenge is to be able to identify the original sales order from a production order a bit down the hierarchy. So I essentially need a codeunit, when you tell it the number of a production order it is able to reply with the Sales Order Number.
If you look at the reservation entries below it is possible to perform this exersice “manually” but I need some code that can do this. For example, the bottom line has Production Order Number 101053 and I can back track that to be connected to the sales order 1016.
https://www.dropbox.com/s/zzmiiv6mi0vk53b/Reservtion%20Entries.png?dl=
