I have seen many posts related to this issue but i dint find any solution
My client has iron business so he has 3 work centres in which he uses some common consumables so he wants to see the consumables consumed for each work centre at the end of the day.
So wat are the things i neeed to do and is there any standard reports for this
So what have you tried and where does it fail?
I would look at the routing link code to enable an operation and work centre based consumption and then run a report on the item ledger entry table for consumption linking back from the production order to the item and the work centre from the parents routing and do it that way, well that is the way I would start anyway.
No there are no standard reports for this.
