I write quantity by ton but it show in item ledger entry by kg why
Hi guys i have problem i buy cement by ton then when i using inside company to make concrete i using by kg
qty unit measure
because when i buy cement item i write in purchase line 42.2 ton
but in item ledger entry it show 42200 ton why
can you give me what setting must found in item card
base unit of measure
purch unit f measure
manufacture policy qty unit measure
why or this normal
Can you be more clear while writing questions.
You mentioned in subject that Item Ledger Entries are having KG’s but in description you mentioned Ton’s only.
What do you have in Item Card’s Base Unit of Measure field? KG?
Thank you for reply
base unit of measure is kg
when drop down list of base unit of measure
kg is first
ton 1000
purch unit of measure is ton
and i buy cement by ton
and consumption and distribution by kg
If your ledger entry has Qty. per Unit of Measure as 1000 then it is normal.
Item Ledger Entries are allways posted with the “Base Unit id Measure”-unit.
This is the way Dynamics NAV is supposed to work.
