I would like to put a variable in a list form that I will post.
How to do so without creating the column in the table form?
Is this possible?
For example:
I want to make a list form on the table section and display a variable where I can retrieve it line by line for the columns of the table unit section
sorry if the english is not too clear, i got this translation from the client :~
thanks
I guess there are some information missing here which i am trying to find out…
Well when you post it you have to store it in a table. I mean the data has to be saved somewhere.
You have to create a field on the table, if you want the values to be accessed while posting. In standard application the fields Receive & Invoice on the purchase header are similar fields which are created to store user input before posting and accessed it during posting
Cheers!
RLH
Thanks guys for all the helpful infos :wink:
Have you tried to use a Function which return a value as the SourceExpr?
-TR-
