I send sample report to you teressa
hi prajeesh what i need not negative value only i want returned order so that to show what i need see this example when i make order like this
doc no order no quantity
12 3 5
after i returned this order he will make as
12 3 -5
to select returned order by writing code the result will be order and returned order(what i need)
12 3 5
12 3 -5
so i want to tell him in coding select any doc no his quantity positive and negative to same doc no
Seems overcomplicated.
Do you apply the return order directly to the order?
If so can’t you used the apply-to Doc number to get the info from the order.
