i want to open my report in excel with the coding in class. but the excel is opening but data in excel not come. the debugger is opening...
i want to open my report in excel with the coding in class. but the excel is opening but data in excel not come. the debugger is opening…
what to code in class…
i am coding such as----
server static boolean TransferSummaryOld(TransDate fromDate = datenull(),
TransDate toDate = datenull(),
str 250 excelTemplateName)
#AviFiles
boolean ret = false ;
ACX_SalesTransferRegister _salesTransferRegister;
ACX_DepotTable _depotTable;
InventLocation _inventLocation;
InventTable _inventTable;
Address _addressTable;
InventDim _inventDim;
InventBatch _inventBatch;
Query query;
QueryRun queryRun;
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
SysExcelApplication _Application;
SysExcelWorkBooks _Workbooks;
SysExcelWorkBook _Workbook;
SysExcelWorksheets _Worksheets;
sysExcelWorksheet _Worksheet;
SysExcelCells _Cells;
SysExcelCell _Cell;
SysExcelFormatCondition _formatCondition;
SysOperationProgress progress = new SysOperationProgress() ;
int _intRow, x ;
int64 totalRecords ;
str 1024 sourceFileName, targetFileName ;
select count(RecId) from _salesTransferRegister
where _salesTransferRegister.PostingDate >= fromDate
&& _salesTransferRegister.PostingDate <= toDate
&& _salesTransferRegister.DocumentType == Acx_SalesRegDocType::TransferShpt ;
totalRecords = _salesTransferRegister.RecId ;
progress.reset();
progress.setCaption(“Exporting Transfer Summary”);
progress.setAnimation(#AviUpdate);
progress.setTotal(totalRecords);
sourceFileName = CompanyInfo::find().ACX_ExcelReportPath + excelTemplateName ;
targetFileName = ACX_UserSetup::find(curUserId()).ACX_ExcelFilePath + curUserId() + excelTemplateName ;
WinAPI::copyFile(sourceFileName, targetFileName, true) ;
_Application = SysExcelApplication::construct();
_Workbooks =_Application.workbooks(); //gets the workbook object
_Workbooks.open(targetFileName) ;
_Workbook = _Workbooks.item(1);
_Worksheets = _Workbook.worksheets(); //gets the worksheets object
_Worksheet = _Worksheets.itemFromName(‘MainData’); //Selects the first worksheet in the workbook to insert data
//_Worksheet.columns().autoFit() ;
_Cells = _Worksheet.cells();
_intRow = 1 ;
query = new Query();
queryBuildDataSource = query.addDataSource(TableNum(ACX_SalesTransferRegister));
queryBuildDataSource.addRange(fieldNum(ACX_SalesTransferRegister, DocumentType)).value(‘TransferShpt’);
queryBuildDataSource.addRange(fieldNum(ACX_SalesTransferRegister, PostingDate)).value(QueryRange(fromDate , toDate));
//queryBuildDataSource.sortDirection(50017 , SortOrder::Ascending);
//queryBuildDataSource.addSortIndex(fieldNum(ACX_SalesTransferRegister, PostingDate));
queryRun = new queryRun(query);
while (queryRun.next())
x++ ;
progress.setCount(x, 1);
_salesTransferRegister = queryRun.get(TableNum(ACX_SalesTransferRegister));
if (fromDate || toDate)
_intRow ++ ;
_Cell = _Cells.item(_intRow, 1);
_Cell.value(Date2Str(_salesTransferRegister.PostingDate,123,2,-1,2,-1,2)); // posting Date
_Cell = _Cells.item(_intRow, 2);
_Cell.value(_salesTransferRegister.SourceDocumentNum); // source document number
_Cell = _Cells.item(_intRow, 3);
_Cell.value(_salesTransferRegister.SourceName); // Source Name
_Cell = _Cells.item(_intRow, 4);
_Cell.value(_salesTransferRegister.SourceStreet); // street Address
_Cell = _Cells.item(_intRow, 5);
_Cell.value(_salesTransferRegister.TINNo); // Tin No
_Cell = _Cells.item(_intRow, 6);
_Cell.value(_salesTransferRegister.TransporterVendorName); // Transporter Name
_Cell = _Cells.item(_intRow, 7);
_Cell.value(_salesTransferRegister.BiltyNo); // Bilty Num
_Cell = _Cells.item(_intRow, 8);
_Cell.value(_salesTransferRegister.OutwardLocationCode); // Outward Location Code
select Name from _depotTable
Join _inventLocation
where _depotTable.DepotId == _inventLocation.ACX_DepotId
&& _inventLocation.InventLocationId == _salesTransferRegister.OutwardLocationCode;
_Cell = _Cells.item(_intRow, 9);
_Cell.value(_depotTable.Name); // Depot
select Name from _addressTable
where _addressTable.AddrRecId == _inventLocation.RecId
_Cell = _Cells.item(_intRow, 10);
_Cell.value(_addressTable.Name); // Location Name
_Cell = _Cells.item(_intRow, 11);
_Cell.value(_salesTransferRegister.ACX_SalePurchType); // Type
_Cell = _Cells.item(_intRow, 12);
_Cell.value(’’); // Batch Type
select * from _inventTable
where _inventTable.ItemId == _salesTransferRegister.ItemId;
_Cell = _Cells.item(_intRow, 13);
_Cell.value(_inventTable.ACX_ChemicalType); // Chemical Type
_Cell = _Cells.item(_intRow, 14);
_Cell.value(_salesTransferRegister.ItemName); // Item Name
/** select * from _inventTable
where _inventTable.ItemId == _salesTransferRegister.ItemId ;**/
_Cell = _Cells.item(_intRow, 15);
_Cell.value(_inventTable.ACX_ItemPrintName); // Item Print Name
_Cell = _Cells.item(_intRow, 16);
_Cell.value(_inventTable.ACX_TechnicalName); // Technical Name
_Cell = _Cells.item(_intRow, 17);
_Cell.value(_inventTable.Acx_PackingSize); // Packing size
_Cell = _Cells.item(_intRow, 18);
_Cell.value(_salesTransferRegister.Quantity); // Quantity
_Cell = _Cells.item(_intRow, 19);
_Cell.value(_salesTransferRegister.UnitPrice); // Unit Price
_Cell = _Cells.item(_intRow, 20);
_Cell.value(_salesTransferRegister.LineAmount); // Line Amount
_Cell = _Cells.item(_intRow, 21);
_Cell.value(’’); // Sales Tax Amount
_Cell = _Cells.item(_intRow, 22);
_Cell.value(_salesTransferRegister.TaxBaseAmount); // Tax Base Amount
select inventBatchId from _inventDim
where _inventDim.inventDimId == _salesTransferRegister.InventDimID ;
_Cell = _Cells.item(_intRow, 23);
_Cell.value(_inventDim.inventBatchId); // Batch Id
select prodDate,expDate from _inventBatch
where _inventBatch.inventBatchId == _inventDim.inventBatchId;
_Cell = _Cells.item(_intRow, 24);
_Cell.value(_inventBatch.prodDate); // Manufacturing Date
_Cell = _Cells.item(_intRow, 25);
_Cell.value(_inventBatch.expDate); // Expiry Date
_Cell = _Cells.item(_intRow, 26);
_Cell.value(_salesTransferRegister.FormCode); // Form
_Cell = _Cells.item(_intRow, 27);
_Cell.value(_salesTransferRegister.ACX_ItemCategory); // Item Category
_Cell = _Cells.item(_intRow, 28);
_Cell.value(_salesTransferRegister.BEDAmount); // BED Amount
_Cell = _Cells.item(_intRow, 29);
_Cell.value(_salesTransferRegister.ECessAmount); // ECess Amount
_Cell = _Cells.item(_intRow, 30);
_Cell.value(_salesTransferRegister.SHECessAmount); // SHECess Amount
_Cell = _Cells.item(_intRow, 31);
_Cell.value(_salesTransferRegister.SAEDAmount); // SAED Amount
_Cell = _Cells.item(_intRow, 32);
_Cell.value(_salesTransferRegister.TotalAmount); // Total Amount
/** select ACX_ChemicalSubtype from _inventTable
where _inventTable.ItemId == _salesTransferRegister.ItemId;**/
_Cell = _Cells.item(_intRow, 33);
_Cell.value(_inventTable.ACX_ChemicalSubtype); // Chemical Sub Type
_Cell = _Cells.item(_intRow, 34);
_Cell.value(_salesTransferRegister.ACX_ItemAppearance); // Item Appearance
_Cell = _Cells.item(_intRow, 35);
_Cell.value(_salesTransferRegister.ACX_Cases); // Cases
_Cell = _Cells.item(_intRow, 36);
_Cell.value(_salesTransferRegister.ExciseTariffCode_IN); // Excise Tariff Code
_Cell = _Cells.item(_intRow, 37);
_Cell.value(_salesTransferRegister.BiltyDate); // Bilty Date
_Cell = _Cells.item(_intRow, 38);
_Cell.value(_salesTransferRegister.Month); // Month
progress.update(true);
info(‘Exported to Excel’);
CodeAccessPErmission::revertAssert() ;
_Application.visible(true); // opens the excel worksheet
/**workbook.saveAs(fileName);
workbook.comObject().save();
workbook.saved(true);**/
return ret ;
Please anybody help me…
Regards
Vijay
