Hi, I am working in AX 2009. My clients wants an urgent requirement. He enter ‘from date’ and ‘to date’ in a dialog or query. I need to get a report according to monthwise the no. of transactionsids in Sales Order. Please help me how can i do this.
i have recently come across this scenario, but it was in ax 2012 ssrs reports.
i am not good in ax 2009 reports , but anyway I will give you the suggestion.
we can solve this by using a switch case .
1)Pass from date and todate to date fields.
2)find out the month of that particular year by using the function mthofyr
eg: switch (mthOfYr(from date))
case 4://April
break;
case 5://May
break;
case 6://June
break;
case 7://July
break;
case 8://August
break;
case 9://Secptember
break;
case 10://October
break;
case 11://November
break;
case 12://December
break;
case 1://Januray
break;
case 2://February
break;
case 3://March
break;
- if you follow the above said logic you can retrive the records on month wise basis.
hi,
Did you find the solution for this scenario…?
i also have the requirement… pls help me in the same
You can use DatemthFwd, DatestartMth, DateEndMth functions.
Dear Mr. Saji
Can you please explain me in detail… i didnt get you
static void Job68(Args _args)
FromDate fromdate = mkDate(2, 3, 2016);
ToDate todate = mkDate(10, 11, 2016);
int startmonth = mthOfYr(fromdate);
int endmonth = mthOfYr(todate);
while (startmonth <= endmonth)
fromdate = dateStartMth(fromdate);
todate = dateEndMth(fromdate);
// your logic here
fromdate = dateMthFwd(fromdate, 1);
startmonth++;
This is the sample code. Just check this. you will get some idea.
yeah i got some idea thanks for your reply… and am i want to write this logic in my fetch method?
Yes, You need to write the logic in fetch method(AX 2009). For AX2012 - Processreport in DP class.
yeah thanks saju… let me try
Ameen
