Hi! Dear all.
I want find a way of comparing two application objects
that one is in this Ax and another is Xpo file from other Ax
Has anyone an idea about, or a solution ?
best regards
Hi! Dear all.
best regards
Hi
Just do as if you were importing the xpo. Go to import, put in the filename. Then, click on “Show details”. A tree will popup with all your elements. Click on on of them with right mouse and select “Compare”.
The Axapta comparison window will open and you will be able to compare your xpo element with the element inside Axapta.
thanks Helmut !
I tried it as you write, and I saw compare screen.
I should study harder AX. hmm…
