Hi guys! do you know where I can find the XML file´s structure of the i.SAF Lithuanian file?
Thanks!
Liana
Thanks!
Liana
Hi Liana?
What is the i.SAF file? Never seen that in Navision?
Hi Erik!
i.SAF file is not related directly to NAV. this is a financial reporting file used by different European countries. Lithuania adopted this file starting with 01.10.2016. all I could find was a XSD schema which doesn´t help me too much.
Hi Liana,
Ahh didn’t know about the “standard audit file”. But then this might be that you are looking for:
