I need Non editable Field
Dear All,
In Purch Table , Field Name Purchstatus is Invoiced mean i need dont editable for the following fied from Purchline
Purchline.qtyordered and
Purchline.purchprice
Please help me , How declared from Farm lavel, I am already declared for
if (purchTable.PurchStatus != PurchStatus::Invoiced)
purchline_ds.object(fieldnum(Purchline,QtyOrdered)).allowEdit(false);
purchline_ds.object(fieldnum(Purchline,Purchprice)).allowEdit(false);
But allow edit, Kindly advice me
Thank You
(purchTable.PurchStatus == PurchStatus::Invoiced)
Hi Sakthi,
If you want to allow edit = false for fields from PurchLine (qtyordered and purchprice) when Purchase Order status is Invoiced, for that,
Ensure that these two form controls from Form design’s property (Auto Declaration should be set as Yes)
then, Instead of your codes,
Add below coding into PurchTable_ds.active() method:
Purchline_QtyOrdered.allowEdit(true); // form control
Purchline_Purchprice.allowEdit(true); // form control
if (PurchTable.PurchStatus == PurchStatus::Invoiced)
Purchline_QtyOrdered.allowEdit(false);
purchline_Purchprice.allowEdit(false);
Lot of Thanks Mr. Hussain
