I have a Question.Help !
When you run a Dataport to import a file, some of the following triggers are executed.
(1) OnPreDataort
(2) OnInitDataport
(3) OnPostDataport
(4)OnPostDataİtem
(5)OnBeforeExportRecord
(6)OnBeforeImportRecord
(7)OnPreDataİtem
(8)OnAfterExportRecord
(9)OnAfterImportRecord
Choose The answer that lists the triggers that are executed in the proper order?
I guess I can copy my response from the other post: So in other words you want the answer to that question from the development exam? Nice try.
Put some message commands in the triggers and see which order they fire in. Or read the section on dataports in the training material.
