I can't not used Analysis Views in GL
Hello If I have license in parts of Application wide – Basic Dimensions not have Application wide – Advanced Dimensions Can I used Dimensions in Analysis Views ? What shall I get feature from Basic Dimensions and Advanced Dimensions ? Thank you
Hi Yes - to use Analysis Views you must have Advanced Dimensions. Basic Dimensions: adds two additional dimensions to the general ledger and to any of the other ledgers. You can assign dimension codes to each transaction that involves a general ledger account, customer, vendor, fixed asset, resource, job or an inventory item. This gives greater flexibility when working with statistics. In addition, it will be possible to define default dimension values and rules for the default values for all account types (G/L, customer, vendor, item, and so on). This will help you add dimensions easily to all transactions. From the GL you can analyse the GL by dimensions Advanced Dimensions: This granule gives you an unlimited number of dimensions to use in transactions in all ledgers. You can name all the dimensions as most appropriate for your business. In addition to an unlimited number of dimensions, the granule includes advanced dimensions functionality. With this granule you can: - Set up rules for how to combine dimensions and dimension values. This will help you control the use of dimensions and make output based on dimensions extremely reliable. - Set up rules for prioritization of default values. This gives you the possibility to define dimension rules to fit your specific business. - Set up and use analysis views. In analysis views you can analyze general ledger transactions per dimension and combine dimensions as you please. You can also include budget information in analysis views. You can combine analysis of dimensions with the use of account schedules. Analysis views are a very advanced way of analyzing data with dimensions information. Requirements: Basic Dimensions
