I’m working on ssrs report using precision desing , all fields of my temporay table are displayd , but the image no !!
knowing that this image is field of my temporary table ( bitmap image), I dont now how to display it.
thank you for help !!
Drag and drop image conrol in report design > Right click on the image control > properties >
Select image source = database
Use this field = select your image field from tmp table
Use this MIME type = image/Jpeg
Click ok.
Before doing this in dp class add below code:
TmpTable.CompanyLogo = CompanyImage::findByRecord(Companyinfo::find()).Image;
Your temporary Table Companylogo field edt should be bitmap type. If you have any doubt check this table PurchPackingSlipHeaderTmp
I solve it , i think the source of probleme was the type of image , my fonction wich i use to populate my field image , return format bitmap public bitmap fonction(), and the image that i use was i other type (*JPEG)t !!
do you know somthing about how i an use the other types ( *.jpeg, *ping,…).
thanks for replying.
Taoufiq
