. I am getting an error that Dialog field object is not initialized
I am trying to use Dialog in the report. I am getting an error that Dialog field object is not initialized… I am using the code given below:
public Object dialog(DialogRunbase _dialog = null)
DialogRunBase dialognew;
//breakpoint;
dialognew = super(_dialog);
dialognew.caption(“Print Details”);
dialognew.allowUpdateOnSelectCtrl(true);
dialogID = dialognew.addField(typeid(PurchName),“Purchase Name”);
dialogVendorAccount = dialognew.addField(typeid(PurchIdBase),“Purchase ID”);
// dialogID.allowEdit(false);
return dialognew;
The error is thrown in the fetch method:
public boolean fetch()
PurchTable _PurchTable;
PurchLine _PurchLine;
boolean ret;
select _PurchTable join _PurchLine where _PurchTable.PurchId && _PurchLine.PurchId == dialogID.value();
ret = super();
return ret;
Please help me to clear this error
Declare a global variable in the class declaration for storing the dialogID.value();.
In getFromDialog() method assign the dialogID.value() to the created variable.
Use that variable in the select statement…
