Has anyone managed to get a hyperlink to a document on a network working with UP. In Navision if you want to open a file on the network you can use HYPERLINK(file:\Server\file.doc) but in User Portal there only seems to be two Type Attributes to the URL Element. These are type Http - to open an external web page or Mail to run MailTo script. Has anyone tried doing this yet in UP
didn’t checked it on the User Portal… but at least with webshop you can send a text and parse your page for opening the file you’re telling the page through that text variable. In html you can use also the file type (file:// ). Alfonso Pertierra (Spain)apertierra@teleline.es
