I am designing a sales invoice report in RTC.
I have two fields
- Text1 2. Value1
The problem is in print preview it is a huge gap between these two fields.
ex:
Text Value
Any solution.
Himanshu Kumar
I have two fields
ex:
Text Value
Any solution.
Himanshu Kumar
Use Alignment,
Set Width of Textbox & Labels
Can you show us the rdlc sceenshot?
Decrease the column size and check…
Do you have any values under it in body section? with CanGrow property TRUE?
can u check text box value may be left alignment and value right alignment check it
checked that
you are talking of which fields?
