Can anyone give me the workspace/front end path to the following forms
HcmPositionForecastAddPosition
HcmPositionDateManager
i get an error when i open them from the development workspace,
HcmPositionForecastAddPosition - requires an active buffer
HcmPositionDateManager -the error says the form was incorrectly called.
In the frontend you can find the HCMPostionForecastAddPostion by
Human resources-> Periodic-> Budget planning → Forecast positions and then click on the new postion you can see three selection items and if you select on the add existing postion you can get the HcmPostionForecastAddpostion Form.
what about the HcmPositionDateManage path
I will check and let you know
Hi John,
Did you manage to check the form path?
