Hello I’m trying to import products with DMF
when I try to " Get staging Data " I get this error " Exception de HRESULT : 0xC001009 ‘0’ ‘Product’ records inserted in staging
Any idea how to fix it ?
Thank you
Thank you
Please give us more information. What is the source of the data? Does it work with other sources? Did it work before? Can you obtain the stack of method calls? Which version of DMF do you use?
Hi first of all thank you for replying
The source data is an excel file; I didn’t try with other sources it’s my first try The version of the DMF is the one from the CU7
