Hi everybocy We are running Navision 3.56 On my HP laserjet 2200 i need to control the upper/lower paper tray My driver is called HP5 and it works perfect, but i cannot figure out how to control the paper tray Can anyone give me a hint ? best regards Michael
Hi Michael, in your printer manual there is a section which defines the ESC-sequeces for the upper/lower paper tray. At the Printer Design in navision go to the “Printer Codes” where you can define “User-defined” Start and End sequences. In your report you can use these “User-defined” printer codes. br Josef Metz
Here is sequenzes, that work for a HP III and is written into “Ny Udskrift”: Upper tray: <27>E<27>&l1H Lower tray: <27>E<27>&l4H Manual feed: <27>E<27>&l3H
Hi Annfinur - that was what I needed - problem solved - Thanks a lot rgds Michael
Originally posted by Anfinnur - 2005 May 02 : 11:57:23
