How we can import the data into two tables by using single object?
Like export data from two tables by using dataport how we can import the data into two tables by using single object? If anybody can help me to resolve this issue it is highly appreciable.
Jithin.
Did you check this/
http://www.mibuso.com/forum/viewtopic.php?t=51656
Hi
do not use table field in dataport instead of that use variables so that you will have the external values in variables , and in “OnAfterImportRecord()” trigger you can insert to the tables which you want.
Jerome Marshal. J
While importing the values, the fiels are not validating. Please suggest me iether we have to call the Validate function or is there any other setups to validate those field while importing? And I wanted to know how to find out the purchase line are imported or manually created?
Jithin Mathew.
Use validate function while assigning values to table…
You have to get purchase line from coding using purchase header data…
Mohana,
Is there any possibility to find out whether the purchase line details are directly imported or manually entered in purchase line form? How we can differenciate both the imported entries and manually created entries?
We cant identify unless you have created any new field in purchase Line…
