How we can create vendor master in ax 2012 using integration (JSON file)?
AIF document services is likely the best tool for this purpose. But it doesn’t accept JSON; messages need to be in SOAP format (which is based on XML).
The message would have to be transformed either by the caller, or you could create a middle-tier service accepting JSON and making a SOAP call to F&O. You could utilize Azure API Management, for example, to do the transformation, instead of developing it on your own.
