how to write these code related to web services...
i want to write some business logic for page and consuming through .net. but how can write these logic plz explain…
The Create method accepts an XML document that represents a table record as a parameter, and returns the record after it is finished. As the record is inserted into the table, the code in the OnInsert trigger of the table is executed, invoking exactly the same processing logic that is invoked by either the Classic client or the RoleTailored client
