Hi, I am using NAV 2009. I have created my reason codes from trail codes. Using Item journal, I have assigned reason codes on the lines before posting. Now when I navigate on item ledger entries, I cannot see the ‘reason code’. Where should I go to see it??? Please guide me. thanks
Only “return reason codes” gets into the Item Ledger Entry not the “reason code”. Although Value entry table contains both reason and return reason code.
