How to use Eligibility events of Payroll module.
Dear all,
When I create eligibility event on Payroll module at this directory:
Human resources/Periodic/Benefits/Eligibility events
Create new “eligibility event”, eligibility type = test.
Add employee & benefit, I got the result:
“This worker has no active employment on the coverage start date.” & this employee is not enrolled.
Input:
Add employee & benefit, I got this error:
System.ServiceModel.CommunicationException: The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error.
Server stack trace:
at System.Runtime.AsyncResult.End[TAsyncResult](IAsyncResult result)
at System.ServiceModel.Channels.ServiceChannel.SendAsyncResult.End(SendAsyncResult result)
at System.ServiceModel.Channels.ServiceChannel.EndCall(String action, Object[] outs, IAsyncResult result)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeEndService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at XppClasses.HcmWkrBenEligibilityEngineService.EndrunEligibilityProcess(IAsyncResult result)
at XppClasses.HcmWkrBenEligibilityEngineServiceClient.XppClasses.HcmWkrBenEligibilityEngineService.EndrunEligibilityProcess(IAsyncResult result)
at XppClasses.HcmWkrBenEligibilityEngineServiceClient.EndrunEligibilityProcess(IAsyncResult result)
Could you please help.
Thanks.
You may need to increase the size of the WCF-NetTcp adapter “Maximum receive message size”. Otherwise, if the responses are large, you may get a System.ServiceModel.CommunicationException: The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error.
