How to use code to give discount?
Hi
I am trying to write a dicount module in AX.
how can i add discount percent or discount amt to line via code?
because i can’t direct assign value to discAmount field.
any suggestion can give me?
SalesTable ss;
DialogButton diagBut;
str strMessage;
str strTitle;
SalesLine newsalesLine;
SalesLineDiscount newsLineDiscount;
super();
strMessage = SalesTable.SalesId; //“The No button should have initial focus.”;
strTitle = “Title”;
diagBut = Box::yesNoCancel(
strMessage,
DialogButton::No, // Initial focus is on the No button.
strTitle);
newsalesLine.clear();
newsalesLine.SalesId = SalesTable.SalesId;
newsalesLine.ItemId = “TEST02”;
newsalesLine.QtyOrdered = 10;
newsalesLine.PriceUnit = 20;
//newsalesLine.discAmount = 10;
newsalesLine.createLine(NoYes::Yes, // Validate
NoYes::Yes, // initFromSalesTable
NoYes::Yes, // initFromInventTable
NoYes::Yes, // calcInventQty
NoYes::Yes, // searchMarkup
NoYes::Yes); // searchPrice
SalesLine_ds.research(true);
SalesLine_ds.refresh();
Do it exactly as you would do that manually. Line-level discount can be set in Discount (LineDisc) and Discount percent (LinePercent) fields.
Thank you.
sorry for this question.
