Assume in AX 2009 you have a field on a table that extends SysDim EDT and represents single Dimension value. Usually it goes together with SysDimension enum which tells us the type of the dimension.
In AX 2012 there is no SysDim field (well… there is but it is obsolete).
Dimension is replaced by DefaultDimension which is the RecId reference to DimensionAttributeValueSet table.
In our case we have single dimension.
What most probably represents single dimension is DimensionAttributeValue table records. But the problem appears when I try to add it to a form. It does not have any replacement key and so shows RecId values which is not good for users.
However DimensionAttributeValueSetItem does not look to be good idea to replace single dimension because it stores elements of the dimension set.
Does anybody knows what would be the best way to upgrade SysDim field to AX 2012?
Respectfully,
Evaldas
