How to update default cube
I have made changes in Retail Cube. Can anybody tell me how to update the cube so that changes can be reflected. Any info or any Doc are welcome
Trish!
Hi Tiwari,
  1. You need to Run the SQL Server Analysis Services Project wizard from BI tools
  2. In that select Update and then select the current Project which is created when we deployed the cubes and complete the wizard.
  3. Then Open SQL server → Analysis server DB → Select the Analysis server DB
  4. Right click the DB and runProcess.
Abbas
