How to transfer Navision Data?
How can i move the modification in Object Designer from one pc to another pc?
You have to export the modified objects from the source database and import those objects to desired database
How? How to copy all those forms and reports in object designer?
Hi Wting5, You will have to first highlight the objects that you need to export (Use Ctrl+F1). Then you will have to export these objects either in text format or .fob format, to a file directory specified, using File-Export. These are basic things which you can learn from your seniors/collegues. You can also refer the documentation for more details. Cheers,
