Hi.
How to take application and Database pack up in ax 2009?
Thanks in advance
Hi.
Thanks in advance
For DB backup, use usual tools for your database management system (e.g. Backup Overview (SQL Server)). An application backup means backing up files from the AX application folder (especially .aod and .ald files).
You’ll find some basic information in Planning backup and disaster recovery.
Thanks martin.
Dynamics AX Database backup is same like SQL server database backup or its differ .
If you use SQL Server as your DB backend, AX database is a SQL Server database.
Thanks martin. am using SQL.
How and where to change the Database name in ax 2009 connections string? then i want to restore live server application to test server. shall i replace the total Application folder or else change some files only… please can you explain?
