how to sum field value using query in dynamic ax 2012
This is the query to sum the field value.
QueryBuildDataSource.addSelectionField(fieldNum(TableName,Field),SelectionField::Sum);
In general, use sum() aggregate method.
If you want an example, are you going to use an AOT query, the X++ query framework (QueryBuildDataSource and such classes) or queries integrated to X++ (select statement)?
Hi
Your requirement can be achieved in this way…
qbds.addSelectionField(fieldNum(InventTrans,Qty),SelectionField::Sum);
