Hi all, I have some legacy data which I extracted from some system and turned them into XML. Now I want to stick the XML into the Navision DataBase. I have created a XMLport to do it, and it works!! However, inside the XML, there is a description element and the length of the description can range from between 10 to alot… At first I thought I can increase the Text field beyond 250… but I guess that’s the limit. I was thinking about sticking the text into a BLOB, but when I try typing stuff into a BLOB from a card form, it doesn’t allow me. I also see that Navision have a Extended Pad, and I was thinking about sticking data into that…but i couldn’t do it since I couldn’t figure out how to split the strings up and stick it into the extended pad… what’s makes my life more worst is I have to display the description in the Invoice, but I know the Invoice text field is only 250 in length… And I believe the XMLPort text field can temporary only hold 1024 characters only… so I don’t know how to deal with large size descriptions in the XML file… Can anyone help me please??
Thanks.
