I pretend delete a empty Tag in a XML file.
With Tag = 0 or empty the problem is not solved, the solution is delete the Tag if tag Value does not exists.
How can I do That?
How can I do That?
Any idear about this issue?
I have exactly the same problem! Please can someone help us?
Hi Luana,
Not really sure what your issue is or what you’re trying to do or where!
Are you trying to create new functionality or changing the existing? Are you using XMLPorts or? Is it even in NAV? [;)]
