How to skip few item Adjust Cost - Item Entries
I have a small query , where i want to skip some item while run the adjust cost batch job .
any one give me idea how to do this.
shailesh
You can put those item in Item no filter by putting
<>Item No|<>Item No
Amol Thanks for reply,
There are near about 500 items for which i want skip adjust cost batch job, so your solution will work on it please suggest. There is a particular one category need to be skip .
shailesh
So you can put that Category in Item Category field
<>Item Category.
This <> Item Category will work, because i have not use this before so not idea about this. please suggest
You can try at least on Test DB.
Okay i will try.
