Hi All
I need to create a total on the bottom of the screen on payment journal screen that shows the addition of all lines - amount field. The pattern I’ve tried is creating a page action that refresh on open that update subpage function to populate fields on new sub page table like:
CurrPage.SetSelectionFilter(SelectedPayJnlLines);
if SelectedPayJnlLines.FindSet() then
repeat
LinesCount += 1;
TotalAmount += SelectedPayJnlLines.Amount;
until SelectedPayJnlLines.Next() = 0;
Two questions:
- Is there a way to refresh total automatically each time user updates the amount field?
2.Is there a function to select all lines without using CurrPage.SetSelectionFilter. I can use SetRange on Batch ID and Template but wondering if there is a better method to select all lines on a given page even if the use selects none (yes, by default 1 line is always selected
