How to Show GST % and values line level in PO report
I want to show GST % and values in PO report line level. In total i can show by below code:
purchTable = purchTable::find(‘02-000164’);
taxDocument = TaxBusinessService::getTaxDocumentBySource(purchTable.TableId, purchTable.RecId);
if(taxDocument)
componentLineEnumerator = taxDocument.componentLines();
while(componentLineEnumerator.moveNext())
componentLineObject = componentLineEnumerator.current();
taxComponent= componentLineObject.metaData().taxComponent();
taxValue = componentLineObject.getMeasure(“Rate”).value().value() * 100;
taxAmount = componentLineObject.getMeasure(“Tax Amount”).value().value();
info(strFmt(“Component %1 ,Rate %2, Amount%3”,taxComponent,taxValue,taxAmount));
The above code shows GST applied against the whoe PO, But Line level I don’t know how to show.
Please Suggest.
Have you tried using \Classes\TaxBusinessService\getTaxDocumentLineBySource?
Hi Kranthi,
thanks for the reply.
while select * from purchLine where purchLine.PurchId == ‘02-000160’
taxDocument = TaxBusinessService::getTaxDocumentLineBySource(tableNum(purchLine),purchLine.RecId);
if(taxDocument)
I tried like this, but throwing error in the below line:
Error : Operand types are not compatible with the operator.
What is taxDocument type? It should be ITaxDocumentLine
I used ITaxDocumentLine and the result is coming in Infolog as:
Component IGST ,Rate 18.00, Amount90.00
Component IGST ,Rate 12.00, Amount120.00
I have 2 lines in PO with different Tax value.
based on above Infolog Msg, how to know which line is belongs to which PO Lines(Item)?
Try printing the purchLine.Item/PurchLine.InventTransId in the info.
Yeah got it…
Thanks Kranthi.
