How to Show all fields in the Packing Slip Inquiries?
Hi to all!
How can I show all fields in the Packing Slip Inquiry if the user accidentally hide the tabs?
If i haven’t closed the form yet after hiding, i can still show it all (command → show all).
Once i closed the form and open it again ( PO details → Inquiries → Packing Slip) I couldn’t expand the form. i cannot see the command in the toolbar.
How can I show all fields or how can i expand the form?
Thank you.
Jullienne
Welcome to DUG :slight_smile:
Did you try deleting the usage data (under Tools > Options > Usage data) just for this form? Hint - once you go to usage data form, look under ‘Form setup’ tab.
Still you should be able to see ‘Show all’ button.Anyways perform following steps-
Right click on form->Show->Show all
