In Dynamics Nav 2013 - I have set up multiple SKU’s in multiple locations using item card as template. Now, I need to add Transfer Fromlocation to thousands of SKU’s. Same Transfer From location to be added to all.
Rapidstart tool is very slow compared to a xml/data port or a report, your partner could do a report very quickly to update all items where replen system is Transfer or get yourself an data port tool
I have used the below for many years and has been great
It’s all about scale thou, if you had 100k+ skus you try exporting that through rapid start and re importing it, a simple report would be a 30 min task and the XML port again is far quicker to run.
Using the right tool for the right job, and who is to say it will only be used once ??
Like wise I may be wrong and op has 100 skus and will never use it again
